Software gratuit - Campanii,giveaway-uri etc...
Rog să-l facă cineva sticky, să postăm aici software-ul gratuit (la momentul postării).
Fără postări cu freeware, cum ar fi LibreOffice,Gimp, Aimp, 7zip, etc.
[u]Ashampoo Home Design 9[/u] - în timpul instalării trebuie să vă creați cont gratuit, apoi primiți cheia de activare.
[u]Ashampoo Photo Optimizer 2024[/u] - după ce instalați Ashampoo App, puteți instala Photo Optimizer prin intermediul acesteia. În Ashampoo App veți avea disponibile mai multe soft-uri gratuite de la Ashampoo.
[u]Hard Disk Sentinel Standard 6.10[/u] - trebuie doar instalat, este preactivat.
multumesc. chiar aveam nevoie de ceva pt poze :smiley:
Super buna colectia de programe gratis :angry:
[u]Hasleo Disk Clone Professional[/u] - gratuit inca 6 zile.
[u]Denoise Projects 3[/u]
“This program enhances your images with noise reduction precisely adapted to your shot. DENOISE projects is the only software that removes all seven types of image noise. You can now relax and shoot in environments that previously did not allow a decent photo.”
To get your license key, [u]click here to go to exclusive SharewareOnSale registration page[/u]. At the registration page, enter your email address, check BOTH of the checkboxes, and click SEND. At the next page, you need to scroll down, fill the form, and click SEND. You must fill out this form. After you’ve done that successfully, the developer will send you an with a confirmation link in it; you must click that link to confirm your email address. Once you confirm your email address, you will be sent another email by the developer that contains your USER ID and REGISTRATION CODE. Keep this USER ID and REGISTRATION CODE safe, as you will need it to register DENOISE Projects 3.
Now, download DENOISE Projects 3 and install it. During install, you will be prompted with a screen where you must enter the USER ID and REGISTRATION CODE you received earlier. Enter it, click OK, and finish installing. Next, run DENOISE Projects 3 and you will be asked to enter a SERIAL NUMBER. In that box, enter the REGISTRATION CODE you received earlier by email and click ACTIVATE NOW. After that, enjoy!
[u]Corel Aftershot 3[/u]
[u]Ashampoo Background Remover[/u]
Ashampoo Background Remover automatically crops objects and makes swapping backgrounds extra easy. Objects can also be manually removed or added. The built-in smart object detection is a huge time saver.
Ashampoo Background Remover crops persons and objects automatically thanks to smart object detection–no manual editing required in many instances. Detected objects can be saved individually or copied to the system clipboard for use with other programs. Even minute details are recognized, like strands of hair. Users can also replace image backgrounds or apply a stylish Bokeh effect. This makes it easy to visually emphasize or put people in completely new scenes. Manually adding or removing objects takes only a few stroke with the built-in correction brush. Ashampoo Background Remover is the time-saving solution for beginners and professionals alike to crop/share objects and replace image backgrounds, no learning curve required.
The download has registration built-in. Download and install Ashampoo Background Remover. During install, you will need to enter your email address. If you have an existing Ashampoo account with that email address, you will need to enter your password to login and that is it: the software will activate automatically, no need to enter any license key. If you do not have an existing Ashampoo account with your email address, you will need to pick a password that you want with the Ashampoo account. You will then be sent an email by Ashampoo and need to click a confirmation link in that email. Once you click that link, that is it: the software will activate automatically, no need to enter any license key. Enjoy!
HT System Administrator
Block unwanted computer activities and increase productivity as simply as possible. With HT System Administrator, block any websites/applications and view reports of computer use in a few clicks.
HT System Administrator is the most reliable and easiest way to manage computer use and block distractions locally or remotely. Make a couple of clicks to reliably block, filter or limit any activity.
You can block or limit any websites, website categories, https sites, programs, games, chats, etc. The program contains the powerful Internet filter to block all inappropriate content. It keeps statistics and shows you detailed reports. A remote control is also available.
HT System Administrator is highly protected. Your rules cannot be bypassed even by the most computer-savvy users. With HT System Administrator anyone can be like a sysadmin.
HSA07-DFUP4-3FR23
[u]EaseUS Disk Copy pro[/u] - valabil inca 24 de ore!
EaseUS Disk Copy Pro is Windows Disk Cloning Software Makes It Smooth and Easy to Clone A Disk
Clone An Old HDD/SSD to A New Computer
When you build a new PC, it’s a great idea to clone all data, files and OS on your old computer’s hard drive to another, and boot your new computer from the cloned hard drive to avoid a new round of reinstallation.
Upgrade Hard Drive Without Losing Data
To resolve a low disk space issue on a computer, nothing is more helpful than replacing the current hard drive with a newer and bigger HDD/SSD. Cloning a disk ensures a smooth upgrade from one hard drive to another as it copies files, programs and OS as they were.
Gilisoft Data Recovery - valabil încă 6 zile și 18 ore de la data publicării
Gilisoft Data Recovery is your ultimate solution for recovering lost or deleted files. Whether you’ve accidentally deleted important documents, formatted your hard drive, or experienced a system crash, our robust software can help you retrieve your valuable data with ease.
With an intuitive interface and advanced scanning technology, Gilisoft Data Recovery supports a wide range of storage devices, including hard drives, USB drives, and memory cards. You can restore various file types, including photos, videos, documents, and more.
Don’t let data loss stress you out! Experience the peace of mind that comes with knowing your files are recoverable. Try Gilisoft Data Recovery now and take advantage of our limited-time offer to get your data back today!
MiniTool MovieMaker - valabil inca 72 de ore
Easy to use and feature-rich video editor
MiniTool MovieMaker is the best video editing choice for beginners. With intuitive interface and rich features, it transforms your video into a piece of art and gives the video a stunning look! It makes your content shine.
One-click Video Editing Experience
With embedded video templates, you can freely export multiple videos and pictures to generate stylish videos. This Windows movie maker simplifies the whole editing process and is especially user-friendly for beginners.
Export 1080P Videos Without Watermark
MiniTool MovieMaker can import almost all video/image formats and save your videos in standard or HD quality. Most notably, it allows exporting videos up to 1080P without watermark, and this is free!
15 programe gratuite până pe 28 octombrie:
https://www.newspivot.com/giveaway/thanks-giveaway/?mt_from=bottomAd&lang=en
Ashampoo Home Design is 3D home design software that allows you to conceptualize and furnish your future home on your PC. Numerous objects help you with interior decoration and you can tour your progress in 3D.E din nou gratuit. Oferta valabila inca 1 zi si 20 de ore de la momentul postarii.
[u]Winxvideo AI[/u] - valabil inca 27 zile.
AI-powered video/image enhancer and converter. Upscale, stabilize, convert, record and edit video. Cinema-grade Quality. Full GPU accelerated.
If you have been bothered by noisy/grainy video, shaky video footage, low-quality images, motion blur video, complicated video editing, file size limitation, format restriction and so on, Winxvideo AI comes as one-stop solution to help you out. As a complete AI-power toolkit, Winxvideo AI can enhance old, blurry and low-resolution video/image, upscale, stabilize, convert, compress, record, and edit 4K/8K/HDR videos smoothly and efficiently, achieving cinema-grade visuals in every frame.
[u]Aiarty Image Enhancer [with Generative AI] [for PC & Mac][/u] - valabil 20 de zile
_Photo & image enhancement software powered by AI to denoise, deblur, upscale images, and generate more image details._Aiarty Image Enhancer is a generative AI image enhancement software that can denoise, deblur, upscale, sharpen and restore AI-generated images, photos, anime, web downloads and more. And it uses artificial intelligence to generate more details and improves the quality & resolution of images, elevating your images to stunning masterpieces.
Key Features of Aiarty Image Enhancer:
 Denoise: remove low-light/high-ISO noise while preserving abundant image details.
 Deblur: turn blurry pictures into high-fidelity perfection without artifacts. Fix motion
blurs, lens blurs, out-of-focus issues.
 More details: generate more realistic details for low-quality images, especially for
hair, fur, feature, skin textures and so on.
 Upscale: enlarge image resolution to 4K/8K/32K for prints, graphic design, e-
commerce and sharing.
 8X upscale and batch process. Optimized for CPU/NVIDIA/Intel/AMD.
 3 AI models trained for any images, e.g. portrait, product, graphic, AI-generated
image, or old photo.
GK Video Downloader - valabil inca 6 zile si 18 ore.
GK Video Downloader allows you to download videos from YouTube, Facebook, Instagram, Dailymotion, Vimeo, TikTok, and other websites. GK Video offers a variety of SD and UHD video quality options, including 480p, 720, 1080p, 2K, 4K, 8K, and more.
In addition to downloading videos, GK Video can also extract audio from videos and save them in high-quality MP3 format. It supports downloading mp3 from most music websites.Testat pe YouTube, nicio problema la descarcare/convertire in mp3. Nu stie insa mai mult de 128k.
oooo bun bun !
Salut! Ashampoo e demential. Am o versiune mai veche de burning software pe calculatorul retro si merge la perfectie. Multe CD-uri cu muzica am facut folosindu-ma de el =)) Chiar recomand!
[u]MiniTool MovieMaker 8[/u] - valabil inca 2 zile si 19 ore.
Ant Download Manager PRO - valabil încă 6 zile și 19 ore
Testat pe Youtube, funcționează.
Boost speeds with Ant Download Manager, the ultimate tool for fast file, P2P, and video downloads. Features include browser integration, MP3 extraction, and a built-in video editor.
Maximize your productivity with Ant Download Manager (AntDM), a high-speed tool designed to accelerate file downloads and capture streaming content effortlessly. AntDM integrates seamlessly with browsers like Chrome, Edge, and Firefox to grab video, audio, and P2P BitTorrent files.
Key features include:
Speed & Reliability: Multi-stream downloading with error recovery and resume support.
Media Mastering: Download TikTok videos, extract MP3s, and use the built-in video editor for trimming or cropping.
Advanced Control: Schedule queues, manage proxy servers, and enjoy 4K support.
GrabTube Pro
GrabTube Pro — Download videos from YouTube, Instagram, TikTok & 1800+ sites in 4K/8K quality.
GrabTube Pro is a powerful desktop video downloader that lets you save videos from YouTube, Instagram, TikTok, Twitter/X, Facebook, and 1800+ websites. Features include 4K/8K quality downloads, batch downloading, built-in video player, format conversion, and smart playlist support. The Pro license unlocks unlimited downloads, all supported sites, and priority updates. GrabTube uses yt-dlp and FFmpeg under the hood for maximum compatibility and quality.
Ashampoo Photo Commander 18Ashampoo Photo Commander is the all-in-one solution for viewing, editing, and managing photos. With over 200 features, the software is the essential tool for digital photography.
Highlights:
– Automatic duplicate photo filter for quickly finding and grouping duplicates
– Four-way fingerprinting for precise image comparison and duplicate detection
– Auto-adaptive UI layout for portrait or landscape orientation
– Auto-listing of city names in GPS data in group view
– Up to 50% faster PNG load times
– New Pop Art, color, and artistic frame effects
– New “Change Color” tool for easy color adjustment
– Improved full-screen mode with new transition effects
– Faster display and zoom for 32-bit photos with alpha channel
The new Ashampoo Photo Commander 18 is a comprehensive software for viewing, editing, and organizing photos. With advanced filtering and grouping options, users can easily manage even massive photo collections. It also supports geotags, allowing images to be sorted by or have their location displayed on a map. The smooth transitions during presentations in up to 4K resolution are impressive and perfect for multi-display setups. Photos can be automatically enhanced or manually edited with the help of various effects. Faded photos, photos with scratches, red eyes, or digital noise can be easily restored. The built-in batch processing feature allows for the automated sequential conversion and editing of any number of images. Creating collages, calendars, and greeting cards is straightforward, with numerous templates and frames for quick results. Similarly, slideshows can be easily generated, complete with background music and seamless transitions. The new version 18 offers an excellent duplicate finder and auto-adapts the user interface based on image orientations. Image loading speeds have been improved, and a progress bar now provides users with progress feedback on running tasks. With support for numerous new image formats, and the ability to filter by XMP and EXIF data, the software meets the latest standards.
Bitdefender Security for Creators - 6 luni gratuit (180 de zile)
