Rog să-l facă cineva sticky, să postăm aici software-ul gratuit (la momentul postării).
Fără postări cu freeware, cum ar fi LibreOffice,Gimp, Aimp, 7zip, etc.
Ashampoo Home Design 9 - în timpul instalării trebuie să vă creați cont gratuit, apoi primiți cheia de activare.
Ashampoo Photo Optimizer 2024 - după ce instalați Ashampoo App, puteți instala Photo Optimizer prin intermediul acesteia. În Ashampoo App veți avea disponibile mai multe soft-uri gratuite de la Ashampoo.
Hard Disk Sentinel Standard 6.10 - trebuie doar instalat, este preactivat.
Software gratuit - Campanii,giveaway-uri etc...
Programe utile pentru diferite sisteme de operare
Ultima oară modificat Vin Aug 30, 2024 2:47 pm de către Cojocel, modificat de 2 ori în total.
Re: Software gratuit
multumesc. chiar aveam nevoie de ceva pt poze
Super buna colectia de programe gratis
Hasleo Disk Clone Professional - gratuit inca 6 zile.
Re: Software gratuit - Campanii,giveaway-uri etc...
Denoise Projects 3
"This program enhances your images with noise reduction precisely adapted to your shot. DENOISE projects is the only software that removes all seven types of image noise. You can now relax and shoot in environments that previously did not allow a decent photo."
Corel Aftershot 3
► Show Spoiler
To get your license key, click here to go to exclusive SharewareOnSale registration page. At the registration page, enter your email address, check BOTH of the checkboxes, and click SEND. At the next page, you need to scroll down, fill the form, and click SEND. You must fill out this form. After you've done that successfully, the developer will send you an with a confirmation link in it; you must click that link to confirm your email address. Once you confirm your email address, you will be sent another email by the developer that contains your USER ID and REGISTRATION CODE. Keep this USER ID and REGISTRATION CODE safe, as you will need it to register DENOISE Projects 3.
Now, download DENOISE Projects 3 and install it. During install, you will be prompted with a screen where you must enter the USER ID and REGISTRATION CODE you received earlier. Enter it, click OK, and finish installing. Next, run DENOISE Projects 3 and you will be asked to enter a SERIAL NUMBER. In that box, enter the REGISTRATION CODE you received earlier by email and click ACTIVATE NOW. After that, enjoy!
Corel Aftershot 3
Ashampoo Background Remover
Ashampoo Background Remover automatically crops objects and makes swapping backgrounds extra easy. Objects can also be manually removed or added. The built-in smart object detection is a huge time saver.
Ashampoo Background Remover crops persons and objects automatically thanks to smart object detection–no manual editing required in many instances. Detected objects can be saved individually or copied to the system clipboard for use with other programs. Even minute details are recognized, like strands of hair. Users can also replace image backgrounds or apply a stylish Bokeh effect. This makes it easy to visually emphasize or put people in completely new scenes. Manually adding or removing objects takes only a few stroke with the built-in correction brush. Ashampoo Background Remover is the time-saving solution for beginners and professionals alike to crop/share objects and replace image backgrounds, no learning curve required.
► Show Spoiler
The download has registration built-in. Download and install Ashampoo Background Remover. During install, you will need to enter your email address. If you have an existing Ashampoo account with that email address, you will need to enter your password to login and that is it: the software will activate automatically, no need to enter any license key. If you do not have an existing Ashampoo account with your email address, you will need to pick a password that you want with the Ashampoo account. You will then be sent an email by Ashampoo and need to click a confirmation link in that email. Once you click that link, that is it: the software will activate automatically, no need to enter any license key. Enjoy!
HT System Administrator
Block unwanted computer activities and increase productivity as simply as possible. With HT System Administrator, block any websites/applications and view reports of computer use in a few clicks.
HT System Administrator is the most reliable and easiest way to manage computer use and block distractions locally or remotely. Make a couple of clicks to reliably block, filter or limit any activity.
You can block or limit any websites, website categories, https sites, programs, games, chats, etc. The program contains the powerful Internet filter to block all inappropriate content. It keeps statistics and shows you detailed reports. A remote control is also available.
HT System Administrator is highly protected. Your rules cannot be bypassed even by the most computer-savvy users. With HT System Administrator anyone can be like a sysadmin.
► Show Spoiler
HSA07-DFUP4-3FR23
EaseUS Disk Copy pro - valabil inca 24 de ore!
► Show Spoiler
EaseUS Disk Copy Pro is Windows Disk Cloning Software Makes It Smooth and Easy to Clone A Disk
Clone An Old HDD/SSD to A New Computer
When you build a new PC, it’s a great idea to clone all data, files and OS on your old computer’s hard drive to another, and boot your new computer from the cloned hard drive to avoid a new round of reinstallation.
Upgrade Hard Drive Without Losing Data
To resolve a low disk space issue on a computer, nothing is more helpful than replacing the current hard drive with a newer and bigger HDD/SSD. Cloning a disk ensures a smooth upgrade from one hard drive to another as it copies files, programs and OS as they were.
Gilisoft Data Recovery - valabil încă 6 zile și 18 ore de la data publicării
► Show Spoiler
Gilisoft Data Recovery is your ultimate solution for recovering lost or deleted files. Whether you’ve accidentally deleted important documents, formatted your hard drive, or experienced a system crash, our robust software can help you retrieve your valuable data with ease.
With an intuitive interface and advanced scanning technology, Gilisoft Data Recovery supports a wide range of storage devices, including hard drives, USB drives, and memory cards. You can restore various file types, including photos, videos, documents, and more.
Don’t let data loss stress you out! Experience the peace of mind that comes with knowing your files are recoverable. Try Gilisoft Data Recovery now and take advantage of our limited-time offer to get your data back today!
MiniTool MovieMaker - valabil inca 72 de ore
► Show Spoiler
Easy to use and feature-rich video editor
MiniTool MovieMaker is the best video editing choice for beginners. With intuitive interface and rich features, it transforms your video into a piece of art and gives the video a stunning look! It makes your content shine.
One-click Video Editing Experience
With embedded video templates, you can freely export multiple videos and pictures to generate stylish videos. This Windows movie maker simplifies the whole editing process and is especially user-friendly for beginners.
Export 1080P Videos Without Watermark
MiniTool MovieMaker can import almost all video/image formats and save your videos in standard or HD quality. Most notably, it allows exporting videos up to 1080P without watermark, and this is free!
15 programe gratuite până pe 28 octombrie:
https://www.newspivot.com/giveaway/than ... Ad&lang=en
